06-19-2015
11:31
08:52
AngelaMa
06-19-2015
11:31
08:52
AngelaMa
I'm having trouble linking my wife's HR device from her gym (Orange Theory) to fitbit. She's interested in having the data transferred over to fitbit so she can review and track her HR results over time on her fitbit dashboard. Is this possible?
06-19-2015 16:28
06-19-2015 16:28
I should add that I'm attempting to help her lync this device to her own fitibit profile.
Best Answer09-28-2015 12:24
09-28-2015 12:24
Were you able to get an answer on syncing with the Orange Theory HR monitor? I have the same question as well.
10-02-2015 15:25
10-02-2015 15:25
@shellcase86 @jarison It's nice to see new faces around. I'm not sure if it's an app that you can link with Fitbit because I couldn't find it in the list of supported apps. However, you may want to contact them directly to see if they have more information.
Let me know how it goes.
07-24-2016 07:33
07-24-2016 07:33
Best Answer07-25-2016 09:38
07-25-2016 09:38
@JAndru A warm welcome to the Community! Currently, Orange Theory isn't a supported app yet. You may want to check the list of supported apps. That's the reason why you're not getting Fitbit data into Orange Theory.
Thanks for your understanding!
Best Answer10-09-2017 10:29
10-09-2017 10:29
I was wondering if you get conflicting data? My OTF says one thing and Fitbit Another....... like 300 calories of difference!🤷🏼:female_sign:
10-10-2017 17:18
10-10-2017 17:18
It's great to have you here @Blondie95! Currently, Orange Theory isn't listed as a supported app. However, Fitbit has a open API, so it's possible to link both applications but they may not be properly syncing. I would recommend to contact OTF directly for more information.
Hope this helps!
Best Answer11-10-2017 08:46
11-10-2017 08:46
What setting are you using when you go to OT? I have a surge and am using the "workout" setting. I too am coming up with different calorie burn. I was wondering which setting would be the best to use when I am working out there.
Best Answer11-11-2017 13:10
11-11-2017 13:10
It's great to have you here @silva6! I believe "workout" is the best option while you're doing OT, because of the exercises that you will do.
Hope this helps! ![]()
Best Answer06-03-2018 22:41
06-03-2018 22:41
Hi
I also go to Orange theory, they are not asking about linking apps. At orange theory we use a heart rate monitor. we want to know if we can link the monitor to get the heart rate into the fitbit app. i use it flex 2 and it does not have a hr feature so it would be nice to get it from their monitor
10-06-2018 07:13
10-06-2018 07:13
I would bet they don't sync since it is unavailable under the devices to set up. The OTF heart rate monitor is going to be the more accurate device while there since they have your profile set up & it knows exactly how hard you're working. You can, however, manually enter workouts into the Fitbit app in order to keep track of them.
08-08-2020 20:44
08-08-2020 20:44
At the end of your OTF session, note down the calories reported on the OTF screen for you.
Then add these as a Workout in the Fitbit app (by going to Days Exercise this week; <+>; <LOG>; select “Aerobics” and enter the start time, duration and calories.
