09-05-2014 19:58
09-05-2014 19:58
Hi There,
I am just seeking some help.
I used digifit with a heart rate monitor to log a workout for the first time this morning.
I can see the workout in digifit, but I cannot see it reflected anywhere in fitbit.
Can anyone tell me where I would find the details on my digifit workout in fitbit?
Is it meant to be logged as an individual item under 'activity'?
Also, how long does it normally take for the digifit info to appear in fitbit?
Thank you for your help!
Rowena
Best Answer09-06-2014 08:04
09-06-2014 08:04
@rowie78 Thanks for stopping by the community! You should re-link them again through your applications. Digifit should sync your activities (workouts) to your Fitbit account. And Fitbit should sync calories and sleep to your Digifit account. Let me know if it works, okay?
Happy stepping! ![]()
Best Answer09-06-2014 18:07
09-06-2014 18:07
Best Answer09-08-2014 06:27
09-08-2014 06:27
@rowie78 Thanks for re-linking both accounts! I highly recommend that you contact Digifit Support. I remember that a couple of months ago they had a bug that was blocking their site from accessing Fitbit data. And something similar happened in January too: Unable to link my Force account to my Digifit account. Let me know if you have another question.
Best Answer09-09-2014 18:15
09-09-2014 18:15
Thanks Stephanie.
I have contacted Digifit, hopefully I can get the matter resolved.
I will let you know what happens.
Cheers!
Best Answer09-11-2014 07:46
09-11-2014 07:46
@rowie78 Thanks for your update! Let me know if you get a response, perhaps we can share it here to other Fitbiters. ![]()
