05-16-2016 18:06
05-16-2016 18:06
Best Answer05-19-2016 10:35
05-19-2016 10:35
Hi @AndreaChristina, welcome to our Fitbit Community. This is the second time I heard something similar. I am looking into this and investigating with my own MFP account but is not giving me this issue although, I know this was a bug fixed the past year.
1. Sign into your Fitbit dashboard.
2. Click the gear icon in the upper right corner and select "Settings" from the drop-down menu.
3. On the left side of your screen click "Applications."
4. Under MyFitnessPal, click "Revoke Access."
5. You can then re-link the two accounts by going to http://www.fitbit.com/apps/myfitnesspal.
After doing this your food should not be multiplied again, now if it does then try to delete the entries from both accounts and enter a new one.
Hope this helps and keep me posted how it goes. If I find something new I will let you know.
