Hi,
I need help disconnecting my fitbit charge 2 from the My Fitness Pal app!
I did google it but since the fitbit app and dashboard has been updated I cant see the area in which to remove it from connecting!
Can anyone help please?
Thanks!
Kelly
If you're having trouble revoking access from the app then you can do it via the web interface.
Go www.fitbit.com and click on the "gear" icon at the top right of the dashboard. Then click on "settings" from the drop down menu and then click on "applications" from the menu on the left. On the next screen you should see the option to revoke access for each of your connected apps.
