06-30-2014 14:39
06-30-2014 14:39
I use My Fitness Pal and Endomondo and they are both connected to my fitbit account. Even though I have entered activiites i nboth MFP & Endomondo, there is no activity in my fitness pal. Is that because I am not using my fitbit device?
Best Answer07-01-2014 07:47
07-01-2014 07:47
I am not quite sure i understand your question. First, make sure that MFP and Endomondo are not connected to each other directly. That can mess up the data.
There is no need to manually enter activity in either if you are entering it in Fitbit. It will transfer over. However, Endomondo currently has a problem receiving activity data from Fitbit. I have a help ticket in with them since last week. They are aware of it but so far have not indicated when it will be fixed.
Where are you looking for the data in MFP? Have you gone here and chosen a Fitbit report?
Best Answer07-05-2014 11:40
07-05-2014 11:40
Sam | USA
Fitbit One, Macintosh, IOS
Accepting solutions is your way of passing your solution onto others and improving everybody’s Fitbit experience.
