08-22-2017
07:30
04:38
RobertoME
08-22-2017
07:30
04:38
RobertoME
I'm currently doing the Ideal Protein Diet and am trying to synchronize my Fitbit Blaze to it but it's not syncing. Does it not pair with the Ideal Protein?
Moderator Edit: Updated Subject For Clarity.
Best AnswerWhile i don't know anythinh anout this fad diet, i assume they have a website and a user account associated with it.
Im not sure if they have set a connection to Fitbit up yet, have you asked them?
You say you did connect the below is an idea of what this would involve.
To connect to Fitbit you will need to through your account on their website. Someplace there would be a page where you would start the connection to your fitbit account. You then will be directed to fitbit to say this is ok.
Best AnswerThis really is a question to ask Ideal Protein. Fitbit has an open API which will allow and website/App to connect up to your Fitbit account .
The fact that third parties do not need to request permission from Fitbit means that there are many more sites that connect to Fitbit. then the small list Fitbit is aware off .
To get an answer I would contact Ideal Protein, doing a quick search I see.It was confirmed the answer was no back in August of 2017.
04:37
04:27
06-09-2018
04:37
04:27
I there everyone, good to see you @SunsetRunner and @Rich_Laue. Let me give you a warm welcome to the Fitbit Community @Mommylou.
Indeed, at the moment there are no further information of an official integration with Ideal Protein and Fitbit that I'm able to confirm. As @Rich_Laue mentioned before; there are tons of apps that use our Open API to integrate their service with ours. So, the best way to tell if an app is compatible with Fitbit is to go to the third party site (or app) and poke around their settings to see if you can connect Fitbit.
You can also browse their site for information or contact the app developer and ask if they integrate with Fitbit or if there is an opportunity of a future implementation.
In our Feature suggestion board there is a request to make this integration possible: Ideal Protein. You might want to take a look if you are interested @Mommylou. Keep in mind the idea, is quite new and may take time to be implemented if align with our future plans. Nonetheless you can vote for this idea and add your comments. We look forward to reading your feedback.
See you all around and take care!
Best AnswerJust an update on this topic.
The Ideal Protein IdealSmart app does now partially sync with the Fitbit. Essentially, you can transfer the steps data over but not sleep, etc.
First, in the PC app, go to My Profile, then click Devices. You can add your Fitbit there.
Sync the Fitbit, then in the IdealSmart app (on Android), from the home page, scroll to Steps, then press Sync/Add Steps.
The steps are likely similar on other platforms.
At the local place, they stopped offering their version because most clients already had a Fitbit. The Fitbit had more features i was interested in so I got one.
