I am using an Alta HR. In the calories section of the app on ios, my nuttacheck calories appear to have gone in twice.
I have 2 nutracheck entries
The first was for earlier in the day - 968
The second was my actual finishing calories - 1151
So now I'm completely over for the week with it showing 2119 overall and I don't seem to be able to edit them.
What can I do to fix it?
Hello @Shanimuffin, and welcome to the Community forums.
Thank you for your inquiry regarding the calories with Nutracheck. I've confirmed that this app is not among the officially supported apps to integrate with Fitbit, but there are many apps, like Nutracheck, that use our Open API to integrate their service with Fitbit.
The best troubleshooting step that could work is that you try to unlink both accounts and then connect them again. You can then check if all your calorie entries are correct before you try to reconnect your accounts to refresh the integration.
I hope this helps, let me know if you have any questions.
