05-07-2016 13:51
05-07-2016 13:51
05-09-2016 15:35
05-09-2016 15:35
05-10-2016 07:19
05-10-2016 07:19
05-14-2016 10:01
05-14-2016 10:01
Hello @Kentstar and @ScarletMynx, welcome aboard to our community. The most basic here would be to make sure the logs are at the correct time, but both of you mentioned this on your previous post so this is not the case. I've seen this before from other user so I will keep an eye on this, as so far there is no issues reported that might affecting the integration between these accounts. My recommendation would be to re-link MFP and Fitbit.
1. Sign into your Fitbit dashboard.
2. Click the gear icon in the upper right corner and select "Settings" from the drop-down menu.
3. On the left side of your screen click "Applications."
4. Under MyFitnessPal, click "Revoke Access."
5. You can then re-link the two accounts by going to http://www.fitbit.com/apps/myfitnesspal.
Keep me posted how it goes, see you around.
