06-07-2017
14:07
08:39
LanuzaFitbit
06-07-2017
14:07
08:39
LanuzaFitbit
I logged into my online concept logbook, concept added fitbit integration at the beginning of May, my erg data excercise carrys across to the Fitbit app now, the heart rate data does not overwrite the Fitbit heart rate on my blaze which is a shame but the blaze is allot closer in excercise mode to my garmin heart rate than my charge hr was. I still have to use the concept calorie calculator for accurate calorie burn but the Fitbit app lets me change the calories burned under the edit excercise section. The raw data calories, time of excercise and distance row all carry across.
Here's the link https://log.concept2.com/blog/integrating-with-other-platforms
Best Answer06-07-2017 18:27
06-07-2017 18:27
@Benshaw627 you have described what's happening but do you have a question?
Best Answer10-29-2017 09:05
10-29-2017 09:05
Hi,
I guess the point is that it is supposed to be possible to view rowing workouts that are posted on the Concept2 log in fitbit. However, I have to admit that I managed to set it up on the Concept2 side, but have not been able to figure out how to display the information on the Fitbit side (my preferred summary place). Any thoughts or ideas would be welcome!
Best Answer10-29-2017 09:11
10-29-2017 09:11
According to this blog it should show up as an activity. It also has a link to more info on Concepts site.
Best Answer10-30-2017 08:43
10-30-2017 08:43
Hi,
Yes, I've followed those instructions, but my rowing has not shown up on my fitbit page. I am wondering if anyone has had success doing this, and could explain how they got everything to work together.
Thanks.
Best Answer01-17-2019 11:17
01-17-2019 11:17
Hi
It worked for me today except heart rate which is from fitbit and not concept2
I just followed the instructions in link then synced data on iphone erg app
Good luck
Best Answer01-21-2019 05:14
01-21-2019 05:14
Hi and thank you. I just re-linked the Concept 2 log to Fitbit and this time it worked. Fun times ahead.
Best Answer01-24-2019 08:41
01-24-2019 08:41
Welcome to the Forums @Traff, Hello @drgaos.
I apologize for the delay in my response.
Glad to read that it seems to be working correctly for both of you!
If you have the time, maybe you could visit one of our Discussion boards. Lots of different topics to talk about with other users.
Let me know if you have any further questions.
Best Answer02-15-2019 20:41
02-15-2019 20:41
Got my Concept 2 data on my Fitbit App on my computer. However the details don't show up on my iPhone, it seems only the set effect of my rowing - calories, etc. Its this normal??
Thanks
Best Answer02-17-2019 09:54
02-17-2019 09:54
Welcome to the Forums @AuroraZ.
Thanks for bringing that up.
If the information is showing on the Fitbit app on a device, I'd recommend that you try to log out of your account and then log back in from both ends. That should force all details to be reloaded from the servers and thus should help so that it all starts working correctly.
Best Answer02-18-2019 12:47
02-18-2019 12:47
Lanuza: Thank you!!
I logged-out/logged-in on my iMac and uninstalled/installed my Versa (instead of login/logout by mistake) on my iPhone. All Erg data synch'd on iPhone now. I will see if it will work for future workouts.
Kudos!!
02-19-2019 09:16
02-19-2019 09:16
Hello @AuroraZ.
Thanks for letting me know.
Glad to read that everything is working correctly after re syncing everything!
If you have the time, be sure to visit one of our Discussion boards. Lots of different topics to talk about with other users. Maybe you will find one that piques your interest.
