02-14-2019
16:18
11:16
LanuzaFitbit
02-14-2019
16:18
11:16
LanuzaFitbit
Why doesn’t Fitbit sync with weight watchers properly?
Weight watchers said it is at your end ?
Any idea when it will be resolved?
Best AnswerHello and welcome to the forums @aladymo
Your post was moved to the Third Party Integration forum area so that it might get better responses. Someone who uses Weight Watchers and their Fitbit will know better how to help you.
While you're here, take a look around the Lifestyle Discussion forum area. You can join in the various discussions, share recipes or get some tips on healthy living. It's a great forum.
Hope to see you around more often.
Best Answer@aladymo I moved your post, so it's there. Just click on the link when you get the email telling you someone posted to a thread you're subscribed to.
Welcome to the Forums @aladymo. Thanks for being around to help @Odyssey13.
I apologize for the delay in my response.
@aladymo In this case I'd recommend that you try to disconnect the two apps and then connect them again. That should definitely help in getting it all to work.
Let me know if you have any further questions.
