12-02-2017
04:38
04:11
RobertoME
12-02-2017
04:38
04:11
RobertoME
Hi,
Does anyone know if its possible to Sync Water Logging in Lose It was Fitbit, I have the premium version of Lose IT and added the Water Intake Goal that alows me to record Water from Lose It, but I cant get it to sync with Fitbit (Food Syncs fine though)
Moderator Edit: Updated Subject For Clarity
12-09-2017 04:08
12-09-2017 04:08
Hello there @SunsetRunner, nice to see you are visiting the Fitbit Community! In this case nore tht not all the third party integrations share all the data from your Fitbit account. It may vary depending of the developer of the integration.
With Lose it, only the following information will be shared:
| What syncs? |
| Fitbit > Calories > LoseIt |
| Fitbit > Aria measurements > LoseIt |
| LoseIt > Food > Fitbit |
So if you are trying to sync water logs, probably this information won't be visible, since the integration was not developed to retrieve or share this data with Fitbit.
For more information about third party integrations, review our Third Party Apps - FAQ.
See you later and let me know if you have other questions!
01-10-2019 08:11
01-10-2019 08:11
At least one ap is misleading then. I am a Premium Lose It user and was given the option to select syncing water.
01-22-2019 12:17
01-22-2019 12:17
+1 would love to see water data sync into FitBit app.
02-17-2019 15:55
02-17-2019 15:55
My hydrate bottle does good
