Hi I'm having problems with my steps from Fitbit syncing to MyFitnessPal. The calories etc come over from MFP on to Fitbit but my steps from Fitbit will not go to MFP.
I can see this topic has come up in the community several times before. I have followed all the advice. Revoked access on both apps, re added the apps and re-synced. I have also uninstalled both apps and logged in and out several times and nothing works.
I can see Fitbit says it's a problem with MFP but MFP says it's a problem with Fitbit.
I just want them to work together any other suggestions?
thank you.
@Xeli03 Welcome to the Community!
Just a heads up, I've moved your post from the Charge 2 forum to the Third-Party Integration forum to help keep the Community organized.
Also, I'd recommend that you try the steps mentioned here.
Hope this helps!
