Exercise not uploading to MFP
I have connected the apps and my food calories from MFP are showing in  Fitbit, but auto recognised exercise calories from Fitbit are not moving to MFP. I manually logged a walk in Fitbit and these calories updated into MFP but no other ones. I am new to Fitbit so may be doing something wrong but any help would be great!
5 REPLIES 5
Personally i find it hard to be doing something wrong with a feature like auto detect that requires a user to do nothing.
Since manualy logged activities sync over, it sounds as if the link is workng.
Autodetect exercises have one disadvantage in thay miles are not recorded,  this might be the key to what you are seeing.
Ive also moved your post to the Third-partyForum which shouod get a better response. Also if you edit the heading to include auto detected exercises the heading will be more accurate.
I have had the same issue for the past week.
I have been having the same problem in reverse. I log my food into MFP and it doesn't sync into FitBit. The FitBit exercise doesn't sync into MFP. This has been going on since the end of December.
Same here.  Started Saturday.
Hello @Wheelarch1@Mel2017, good to have you here in our Community. Also nice to see you again @Maura1171 and @SunsetRunner.
@Rich_Laue has provided a great piece of advice, for MFP integration with Fitbit.
If you are having issues with syncing and think the following post might be of your help: Fitbit and MFP not syncing! Take a look at it and give it a try!
Keep me posted, I'll be around for additional help.
Roberto | Community Moderator
