02-01-2017 13:49
02-01-2017 13:49
When I transfer my run workou from fitbit to endomondo I get lots of stats. But one of them is very off.. I highly doubt I will ever run at 142 km per hour...
Best Answer02-03-2017 04:28
02-03-2017 04:28
Hello @Shauri, Welcome to our Community boards. I wonder how are you recording your GPS activity? Are you using Connected GPS or the mobile app feature MobileRun?
In the meantime I recommend to disconnect the integration from your two account and re-link again both of your accounts:
Each time your tracker syncs to fitbit.com, the data will also be uploaded to Endomondo under your workout tab. By default, all the workouts you make on Endomondo are posted to Fitbit under your manually logged activities. You can disable this setting by going to Settings > Connect and unchecking Auto-Post New Workouts to Fitbit.
For more information, see Endomondo's Fitbit integration support page.
Hope this information helps. Keep me posted how it goes.
