10-24-2014 11:56
10-24-2014 11:56
I use the Good Run Guide to log my runs, spins and other stuff. Can I export my FitBit data to this as TXC or GPX? I know nothing about the types of files but this is what they say I need. Thanks 🙂
Best Answer10-30-2014 13:30
10-30-2014 13:30
As mentioned above, there is currently no .gpx export option. If this feature interests you, I'd recommend voting and commenting on the associated feature request.
10-25-2014 07:59
10-25-2014 07:59
If you purchase a Premium account, you can export your data in .csv or .xls format. Those are your only options.
10-30-2014 13:30
10-31-2014 08:29
10-31-2014 08:29
Done!! 🙂 Thank you for the suggestion.
