01-22-2018 08:52
01-22-2018 08:52
Everything was working fine, til Saturday night. Now all my activity has been lost with the app. Both are set up and showing they are conncted, but the information from Fitbit NOT showing up in Weight Watchers, and it deleted the past.
Best Answer01-27-2018 06:23
01-27-2018 06:23
Hello @Hsimard5240, nice to have you here in the Fitbit Community, welcome aboard! In this scenario I saw your previous data from Weight watchers was deleted. Note that Fitbit only share information across the integration but does not have the access to delete information in third party services.
In this case make sure your Weight watchers does not contain a variation in the email address used to registered your account. I've seen this happen in the majority of these issues.
If nothing of this seem to be the issue, try to connect your accounts one more: Usually I do not recommend to do this, but this is a special case, go ahead and revoke the access from WW in your Application settings using your web-Dashboard.
Once you have done that, return and proceed to the steps to connect again your accounts:
Hope this helps and keep me posted in case you need more help.
