04-10-2016 13:28
04-10-2016 13:28
Best Answer04-10-2016 18:08
04-10-2016 18:08
Welcome to the Fitbit Community @tortugita718. It's great to have you here. The gear is found in the online Dashboard only. It is not located in the Fitbit app.
You can visit the online Dashboard and go here to revoke access between your Fitbit and MyFitnessPal accounts. Then, please link them once again by following these instructions. Hope this helps.
I moved this thread to the Third-Party Integrations because it's more related to the topic. Catch you later.
04-11-2016 02:59 - edited 04-11-2016 03:01
Basically, My Fitness Pal just takes the information on your Fitbit dashboard once linked. There are other third party apps https://www.fitbit.com/partnership
Best Answer04-11-2016 13:04
04-11-2016 13:04
Best Answer04-12-2016 19:40
04-12-2016 19:40
Best Answer04-14-2016 22:15
04-14-2016 22:15
@tortugita718 If you don't have the option to revoke access between Fitbit and MyFitnessPal this means that your accounts are not linked. It should look like the following screen shot:
Please log into your MyFitnessPal account and select APPS > App Gallery > scroll down until you see Fitbit Tracker, select that option and link both accounts.
Let me know how it goes. Keep up the super stepping. ![]()
Best Answer04-15-2016 07:03
04-15-2016 07:03
Best Answer04-15-2016 13:43
04-15-2016 13:43
@tortugita718 In this case it could be a good idea asking for support in MyFitnessPal. You can get in touch with them through this link.
Thanks for stopping by, see you around. ![]()
