03-26-2025 10:06
03-26-2025 10:06
My charge 6 stopped working/syncing with My Fitness Pal. When I try to reconnect to MFP, I keep getting an error that says "to connect to FitBit account please allow MFP to access all FitBit Data points" which I did. Or, I get a message saying "there was an error trying to connect." Anyone else have this issue?
03-26-2025 12:50
03-26-2025 12:50
I’m facing the same issue. Fitbit says they’ve resolved the issue but the problem seems to persist. I tried their resolution multiple times but it doesn’t work: this is so frustrating. I’m a new Fitbit customer, I’d purchased charge6 so it could connect to MyFitnessPal. But if it doesn’t, I’d rather return the product and buy an Apple Watch.
03-26-2025 12:53
03-26-2025 12:53
03-26-2025 15:34 - edited 03-26-2025 15:34
Yep. Same issues here since yesterday. Fitbit Charge 6. Stopped syncing. Android v14, Fitbit v4.38(110235289), MFP v25.11.0-40427
Best Answer03-27-2025 00:42
03-27-2025 00:42
Looks like it's been sorted. Seems ok now.
Best Answer03-27-2025 05:59
03-27-2025 05:59
03-27-2025 20:47
03-27-2025 20:47
Sorry to hear that. Mine is still ok, so you must have a different issue. Mine works fin for months, then there will be some sort of FB/MFP update that throws everything off for a while. It wasn't working for a couple of months last year while FB/MFP sorted out the issue. Since then although it stops working occasionally, they seem to get it working again pretty quickly. Fingers crossed you get your issue sorted.
Best Answer03-31-2025 15:30
03-31-2025 15:30
It finally working! Looks like MFP figured it out
Best Answer03-31-2025 15:59
03-31-2025 15:59
