04-03-2016 16:58
04-03-2016 16:58
I'm a regular user of both FitBit and FitStar, but am a bit puzzled by the integration via my Charge HR. For example, I did a 21 minute FitStar workout today that was very strenuous. When it synced to my fitbit dashboard, my heart rate barely registered (I know arm movement is an issue with Charge HR accuracy), it only registered 70 calories burned, and accounted for only 7 active minutes. This kind of thing keeps happeneing with my FitStar workouts, and I keep having to delete and re-enter them manually on FitBit dashboard. Any experience with this? FYI that when using FitStar, I do not use exercise mode on my Charge HR. Thanks.
04-04-2016 12:35
04-04-2016 12:35
I'm having the same problem as bobsmart567. My FitStar Yoga sessions are being recorded on fitbit but not accuratly. on 4/2 I should have received 130 cal, and 30 min. of active minutes but Fitbit only showed 23 cal. and 0 active min. Similar results showed on my 4/3 and 4/4/16 exercise classes. I tried loging out of my iPhone, iPad and web and signing back in but no change. Help.
04-06-2016 20:38
04-06-2016 20:38
I'm having the same problem using my Charge HR. I have been using FitStar since they first partnered with FitBit and it has always transferred the calorie amount listed in the FitStar menu directly to the FitBit app. As of the last few days a 126 calorie workout transfers at around 50 calories.
04-18-2016 05:12
04-18-2016 05:12
