I have seen a few posts on this but nothing has solved my problem. I paired the Fitday and Fitbit app and both show successful pairing yet my weight data from my scale does not load into my Fitibit app. I tried disconnecting a repairing and that did not help.
09:18
04:56
10-12-2022
09:18
04:56
Hi there @sboden2315, it's good to see you back in the Community.
I'd recommend you follow the instructions on How do I connect my Fitbit account with another app?. Some users usually find it useful to unpair and then pair both apps again to refresh the performance, if you already have them paired.
Also you can try to restart your device after completing the steps above.
If you continue having the same problem, please contact our Support Team or the third party customer service.
Have a nice day.
10:40
04:56
10-12-2022
10:40
04:56
Hi @sboden2315, I'm glad you came back.
I understand how you feel and appreciate the troubleshooting steps performed.
Thank you for reaching Support Team and you can also contact the third party customer service as well for further information.
I'll be around.
08:40
04:26
10-16-2022
08:40
04:26
I appreciate you share your experience. Fitbit devices share information with a third party app but not the way around.
It's up to the owner of the third-party app to implement or update features for their app, this needs to be addressed with the third party customer service and if you wish you can also add a Feature Suggestion so our team can consider it for future developments.
Also you can make this suggestion to their support team and direct them to our existing API and SDK and resources such as the web dev API community.
Hope this helps.
