Hallo,
I used my Fitbit luxe to tracker my running. Now I started a workout plan with runkeeper. How can I tracker my workouts with the Fitbit and also use the workout advice from Runkeeper without having my workouts trackered twice? The two apps are already connected and the Fitbit gives the data to Run keeper. Bit if I start Runkeeper for the workout advices I have two workouts on my Runkeeperapp ( one from Fitbit, one from Runkeeper). Is there a solution to use both and not having two Runs on the Runkeeperapp?
Thank you. I tried to debate one. But it comes back from the Fitbit very soon because the cure connected...🙄
Best AnswerThat may be a problem... 🤔 you may try different workaround. Disconnect both accounts before your Runkeeper workout and re-connect after. There shouldn't be any sync for runs during time both apps were disconnected.
