08-31-2016 17:11
08-31-2016 17:11
I ran 1 hour today at a 9:43 pace, my Fitbit says I burned 599 calories from running and an additional 63 from walking throughout the day. The Fitbit Tracker calorie adjustment on MFP says 390? I'm confused?
08-31-2016 17:22
08-31-2016 17:22
Hi JuleeO
Have moved this thread from the Get Moving to the Third-Party Integrations section to increase the chance of getting a solution.
Your post will get more attention here.
08-31-2016 17:26
08-31-2016 17:26
Thanks for accepting as solution Julee, has the issue been solved?
08-31-2016 17:31
08-31-2016 17:31
08-31-2016 17:38 - edited 08-31-2016 17:41
Have unaccepted as solution, otherwise other awesome community members, fitbit moderators.. may believe the issue has been solved, indicating not needing help anymore..
08-31-2016 18:45
08-31-2016 18:45
09-03-2016 14:38
09-03-2016 14:38
@SunsetRunner Thanks for moving the post to the correct board.
@JuleeO Welcome to the Community! The calorie adjustment will be made when the total daily calorie from Fitbit is greater than your MFP total. If Fitbit projected a total less than your MFP then you'll see a 0 or a negative adjustment (if you have it enabled).
You can learn more about the calorie adjustment made on MyFitnessPal here.
Hope this helps.
09-03-2016 14:42
09-03-2016 14:42
*fingers crossed*
