03-25-2021
15:57
09:06
03-25-2021
15:57
09:06
So I have my fitbit app and Myfitnesspal app synced but some things won’t sync. Weight will sync but not my steps or exercise. Also when i log my food into myfitnesspal it doesn’t show up on the fitbit app. I’ve tried to revoke access and reconnect but it still doesn’t work. Anybody else know how to fix it?
Best AnswerAs with most third-party apps, the best we can suggest is these steps .
If this fails, you will need to directly contact the third party who is responsable for maintaining this connection.
Best AnswerIf you already have revoked access and then setup the link with MFP, and this step failed...
Please contact MFP. They setup the ability to link up with fitbit.
They maintain this link.
They are the only ones who can fix this.
If you are getting sick of MFP have this issue, then find some other app.
If the problem was on fotbit's side, we would have sync issues with many many different apps.
This is not something we are fitbit will be able to fix.
Best AnswerWell then preferably they or you need to contact fitbit.
But this board is full of MFP posts. I don't see many posts about other apps.
We have already explained the only step that can be done.
