03-17-2021
03:54
11:20
WilsonFitbit
03-17-2021
03:54
11:20
WilsonFitbit
Hello everyone, I am new to the community. I got my fitbit yesterday and I have a question.
When I add exercise to myfitnesspal, it looks like activity is doubled. My question is, will the calories double up too? Because I dont want that.
Best Answer03-19-2021 11:26
03-19-2021 11:26
Hello @Rapathy, welcome to the community forums!
This is odd but I would recommend re-inking your MFP and Fitbit accounts by doing the following:
On the Fitbit App:
On the Fitbit.com dashboard:
1. From the fitbit.com dashboard, click the gear icon An icon of a gray gear > Settings > Applications.
2. Click Revoke Access to disconnect an app from your Fitbit account.
A couple things to consider about your MFP - Fitbit Integration:
Also, all food and water items must be logged through MFP and your steps, exercises, manual logs and other activities need to be logged through Fitbit; this will prevent any double logging or incorrectly increasing your caloric budget for the day. They connect seamlessly and transmit information between each other so your caloric budget is on a continuous update.
Hope this helps!
Best Answer03-23-2021 17:47
03-23-2021 17:47
It is doubling my Calories. I have unliked and relinked the two FOUR times. No change. Seems to have been happening for the last week.
Best Answer03-29-2021 10:41
03-29-2021 10:41
Hello @add0068 Welcome to the community forums!
I recommend logging Food through MFP, and your steps, calories, scale measurements (if applicable), please log them through Fitbit; this will prevent any double logging or incorrectly increasing your caloric budget for the day.
If you need further assistance, I recommend contacting MyFitnessPal support.
Hope this helps!
