03-29-2021
12:33
17:23
LizzyFitbit
03-29-2021
12:33
17:23
LizzyFitbit
For two days my Fitbit is not syncing with MFP app. Please help. I have turned Bluthtooth on and off several times. Same with WiFi. Have restarted my phone several times. Nothing seems to help. I don't know what else to do. Thanks
Moderator Edit: Clarified subject and updated label
03-29-2021 23:00
03-29-2021 23:00
hi there. i have the same issues. obviously MFP has some issues. what you can do is the following: delete fitbit from your mfp account by removing fitbit in the MFP account under APPS.
Then go to fitbit and revoke the access of MFP in the settings then go to applications. then go back to MFP and link fitbit tracker again. then it should sync
https://support.myfitnesspal.com/hc/en-us/articles/360032623011
03-29-2021 23:32
03-29-2021 23:32
@Neto8548 the problem is not with fitbit. But is between MFP and your Fitbit account.
