I had a Medtronic Pacemaker / Defibrillator installed in my upper left chest and set to 60 bpm. When I met with a rep at the doctors office, I was talking about the pacemaker making my Fitbit Charge 2 to always show 60 bpm. My wife suggested at that time to move it to my right wrist. Well, now I am showing what my heart is actually doing. When I take my blood pressure on my left wrist, it is always showing 60 bpm. There are a lot of things that you have to look out for when using a Pacemaker / Defibrillator. One was, to not use a body fat percentage scale. Well it turns out that the Aria scale does not affect my Medtronic Pacemaker / Defibrillator. So far so good. Thanks.
Hello there, @CCRANGER! Thanks for sharing your experience with us!
I'm sure this tips will help others that are in the same situation as yours to obtain better and more accurate results. I'm glad to hear that you are doing better now using your Fitbit devices.
I hope to continue seeing your face around here, make sure to check out our cool Discussion boards. ![]()
CCRANGER,
I have just put up a post about Fitbit and pacemakers - then I found yours. I think my Fitbit Charge 2 is being deceived into thinking I am not asleep because my HR does not go below 63 BPM when I am sleeping. After several hours - possibly after also looking at my hand movements - it eventually seems to decide I am asleep !! Have you had this problem ?
PS - I will try changing wrists to see if that changes anything !!
my fitbit3 gives very high bpm readings when I am exercising at a fast walking pace.
My defibrillator is set at a max of 120 bpm but my fitbit reads 150bpm.
mike
Best AnswerUnless you are in your 80s I wouldn't think your defib is set to 120. I think mine is set to 200 I'm 43.
Best AnswerI am 71 and I have experienced 8 heart attacks. My Medtronic is set to 60 bpm. I have been working on a house and I can get up to 123 bpm. l can get a heart MRI and they raise my bpm to 80 on my unit and then set it back to 60 bpm after the testing is done. I updated to Versa 2. I like it because I can see what is going on when I am outside.
Best AnswerNot necessarily true. Why would they set your BPM to 200? Mine is set to 60 and I was 37 when received my first ICD placement.
