07-07-2015 09:38
07-07-2015 09:38
I can't get the fitbit dashboard to synch with fitstar at all. I had the app on my ipad, so that I could do the workouts, but no matter what I do, I can't get fitbit to see those workouts. I took the fitbit app off the ipad and only left fitstar. I tried to revoke access to fitstar from the fitbit settings, but I get an error that there is a server issue. I created a username and password on fitstar, and this didn't help. Does anyone have any ideas how to fix this? Or at the least, how to revoke access to fitstar through the fitbit website? Thanks in advance!
07-16-2015 09:14
07-16-2015 09:14
It's nice to see you around @Koda1021! Well if you're using a Fitbit app I was wondering if you have checked that you're running the latest version of your Fitbit app? check it and let me know how it goes after. ![]()
Best Answer07-21-2015 02:41
07-21-2015 02:41
Best Answer07-21-2015 07:22
07-21-2015 07:22
Hey, I'm glad to have you here sweetie @Kikirkni! I was wondering if you're using an Android or an iOS phone to sync your tracker
. Have you tried restarting your One? ![]()
Best Answer07-21-2015 19:29
07-21-2015 19:29
Best Answer07-22-2015 02:58
07-22-2015 02:58
Best Answer07-31-2015 12:42
07-31-2015 12:42
Best Answer08-01-2015 06:49 - edited 03-08-2024 03:50
Hi everyone, have you tried revoking access and they try linking Fitstart with Fitbit?
P.S. Welcome to the Forums @SaylorMan, I'm glad to see you around! ![]()
Best Answer08-01-2015 11:02
08-01-2015 11:02
Best Answer08-03-2015 04:39
08-03-2015 04:39
Thanks for the details @SaylorMan. My best suggestion would be to contact Fitbit Customer Support directly; they'll check your account to see if your FitStart is properly linked with Fitbit and how you can connect both apps. Don't lose the hope yet my friend!
