10-16-2024
04:52
11:26
LizzyFitbit
10-16-2024
04:52
11:26
LizzyFitbit
Steps,calories etc not syncing to app or my fitness pal. Its been happening for awhile
Moderator Edit: Clarified subject and updated label
Best AnswerHi, @Jackiestrydom. welcome to the community. I'm using MFP (and Withings) on my Pixel 8 Pro and have set up "Health Connect." In MFP I get an exercise calorie count (which I'm pretty sure comes from the Fitbit app) and weight from Withings but I have to enter the food calories manually in the Fitbit app. As an aside, the Withings scales weight transfers as expected to the Fitbit app. Steps used to appear in the Withings & MFP apps but no longer do so. I know the intention is that with the Health Connect settings set up as described, how do I use Health Connect in the Fitbit app? - Fitbit Help Center should all work seamlessly in both directions. I suspect that some of the contributing difficulty is with the Withings & MFP apps being slow to adapt to the Google/Health Connect/Fitbit Health Connect feature.
Let's call it "a work in progress"?
Cheers
Gr4ndp4 | UK
