04-06-2020
22:48
09:59
AlejandraFitbit
04-06-2020
22:48
09:59
AlejandraFitbit
I used to be able to see weight from my Yunmai scale on my Fitbit app. Ever since I had to go a factory reset on my phone, I cannot get the two to link.
Help
It's great to see you around, @mle8.
I am sorry for the delay in response, due to recent events affecting our operations, support options are limited and wait times are longer than usual.
Also, I wanted to let you know that I have moved your post from the Charge 3 board to the Fitbit app Gallery board, since I think that you will be able to see more topics about other apps here.
Now about your issue, you can only sync the Fitbit app with the Fitbit scales. For more information, check the article: How do I get started with Fitbit scales?. If you are using other app, you should contact their customer support.
Let us know if you need anything else.
Best Answer@mle8 it is true when we say the Fitbit app does not work with Yunmai.
It is your Yunmai account that syncs to your Fitbit account.
When it stopped working with the phone restart, on fitbits side is simply a red herring.
Without knowing anything about your scale, it might be that you have to setup the link through your Yunmai app, the way you did when setting it up at first.
