06-17-2019 14:53
06-17-2019 14:53
Hello. I have an issues with the sync between MyFitnessPal and Fitbit. I have unlinked the accounts and re-linked them. My food log / calories sync fine but the weight is not being synced. I can see measurements being reported in MyFitnessPal but the last one to sync to Fitbit was April 15th 2019.
Please let me know what I can do to fix this. Thanks!
Best Answer06-19-2019 05:01
06-19-2019 05:01
Hello @LanuzaFitbit. I have since connected my Withings/Nokia Wi-Fi scale with my Fitbit account to get the weights to sync.
Previously it had worked having my weights synced to MyFitnessPal through the Withings/Nokia scale and then it would sync to Fitbit. There must have been a change of software along the line that caused this not to function anymore.
Thanks!
Best Answer06-18-2019 09:18
06-18-2019 09:18
Welcome to the Forums @BarryF.
Thanks for sharing your experience and everything that you have tried so far.
In this case you are not experiencing any issues, weight is not shared between the two apps unless it was logged from an Aria scale. Are you using an Aria scale to log your weight to your Fitbit account?
Please let me know if there are any other questions I can help you with.
06-19-2019 05:01
Thanks!
Best Answer09-18-2019 17:52
09-18-2019 17:52
I am using a aria scale and it's not syncing to myfitnesspal
09-19-2019 21:16 - edited 01-06-2020 06:42
You can sync weight to MyFitnessPal (Under Armour) also with WeightNet, a free real-time web integration available at www.weemple.com
Best Answer09-20-2019 06:52
09-20-2019 06:52
Although my Fitbit Blaze and Aria are working just fine and the data appears on my dashboard it no longer syncs with my fitness pal app. It was working fine until about two months ago. Have spent lots of time trying to resolve on my own but can’t figure it out. Help.
Best Answer10-16-2019 21:25
10-16-2019 21:25
I have an Aria, Fitbit Versa and MFP. Everything is synching between them except for weight. The weight is taken by Aria and goes to the Fitbit tracker. From there, nothing. It should show up in MFP, but it doesn’t. Please help. If it’s no longer a function if the pairing simply say so and I’ll stop trying.
04-28-2020 11:23
04-28-2020 11:23
06-15-2021 08:07
06-15-2021 08:07
I've been waiting for this for more than a year, and had no idea the connection to Withings had finally been implemented. There is nothing showing that's possible in the Withings Healthmate App, which is sad. I'd given up hope.
Thanks, Java, if I could, I'd mark your response as the best answer because it actually answers the question and provides info on how/where to accomplish the task which formed the basis of OP. I love it when people actually provide helpful information as opposed to simply saying what they did without instruction or guidance. Well done.
