12-02-2025 06:09
12-02-2025 06:09
I followed the instructions in this comment by a moderator. Exercises in Fitbit are still not being transferred to Strava. Strava activities do appear in the Fitbit exercises. What further troubleshooting steps should I take to resolve this problem?
12-02-2025 08:39
12-02-2025 08:39
Hi @j-ftbt in the past, was Fitbit syncing to Strava?
I just checked, yes my GPS recorded activities are syncing with Strava.. Please not, that only activities that are recorded with GPS enabled will sync. Currently I believe only Walk, Run, Hike, and Bicycle sync. I would like Kayak also.
Normally when they're not syncing, we want to to disconnect then reconnect.
Fitbit App:
Strava App
Once BOTH applications have been revoked respectively, restart the authorization process by referring to the steps below:
Strava App
1) You > Settings (gear icon)
2) 'Connect to an app or device'
3) 'Fitbit'
4) Follow instructions to authorize Fitbit and Strava to connect
Best Answer12-02-2025 08:57
12-02-2025 08:57
@Rich_Laue, thanks for the long response. Neither Walk nor Run exercises are syncing to Strava. The instructions you listed are the same that I linked to, and I have followed those instructions. I have followed them several times over the last week or so. Still, neither Walk nor Run exercises recorded on the Fitbit appear in Strava. I am assuming the connection is created correctly since Strava activities appear in Fitbit's UI. Are there any other troubleshooting steps I should take to determine what could be wrong?
Best Answer12-02-2025 08:58
12-02-2025 08:58
Sorry, to answer your question "was Fitbit syncing to Strava?". No, I have never seen Fitbit exercises appear in Strava.
Best Answer12-02-2025 09:46
12-02-2025 09:46
The Fitbit website shows that the device has GPS turned ON for Walk, Run, and Bike. I did not just turn those ON, they were already checked.
When I select "Export as TCX file" in the Fitbit mobile app the downloaded TCX file seems to essentially be empty as shown here:
<?xml version="1.0" encoding="UTF-8" standalone="yes"?>
<TrainingCenterDatabase xmlns="http://www.garmin.com/xmlschemas/TrainingCenterDatabase/v2">
<Activities>
<Activity Sport="Running">
<Id>[...a timestamp...]</Id>
<Creator xsi:type="Device_t" xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance">
<UnitId>0</UnitId>
<ProductID>0</ProductID>
</Creator>
</Activity>
</Activities>
</TrainingCenterDatabase>
Hopefully, this additional information is helpful.
Best Answer12-11-2025 18:46
12-11-2025 18:46
For you to see a TCX file, you would need to record your Fitbit exercise with GPS enabled, also only exercises with GPS map recorded will be spent to Strava.
In Fitbit, do you see a map of your Walk, Run, or Bike ride?
Best Answer12-11-2025 18:52
12-11-2025 18:52
No. However, GPS is turned on. So, maybe the problem is that Fitbit is not honoring the GPS setting in the Fitbit options?
Best Answer12-11-2025 18:54 - edited 12-11-2025 18:55
I have been back and forth about this with Fitbit and Strava.
Strava claims that Fitbit pushes Fitbit exercises to Strava; so the problem must be on the Fitbit side. This makes sense to me and aligns with how all API integrations I have used operate.
Fitbit claims Strava pulls Fitbit exercises from Fitbit; thus the problem must be on the Strava side. How Strava is supposed to know there is a Fitbit exercise to be pulled has not been explained.
Best Answer12-30-2025 15:23
12-30-2025 15:23
Did you ever get your ersa 4 to sync? I have the same problem!!!
Best Answer12-30-2025 19:30
12-30-2025 19:30
Yes @j-ftbt Fitbit is the manager of the Strava and IFTTT. As for as I'm aware of, all the other apps that sync are handled by them.
You say the TCX file is empty, and you do not get a map of your runs, walks and hikes. If you have an empty TCX file, then fitbit doesn't have any data to send to Strava.
If you are not getting a map. I'm not sure which tracker, but SWR your settings. Also on the tracker you will see an icon that tells you the GPS status. If you haven't restarted the tracker, I'd try that. If your tracker uses the phones GPS. Make sure that the phone is with you and the tracker is connected.
Best Answer12-31-2025 00:28
12-31-2025 00:28
Rich any advise for helping me get my versa 4 to load to strava? Everything is there but for some reason just does t load to Strava. Fit it blaming Strava and Strava blaming Fitbit- me stuck with a watch not really fit for purpose. Will be my last Fitbit for sure!!
GPS on, map on Fitbit, nothing on Strava - have deleted connections, reattached, turned everything off and on, closed apps and restarted!!!
