09-13-2018 19:18 - last edited on 11-12-2021 06:34 by AndreaFitbit
I have a new Versa that so far I love. The only problem I’m having is using with my Weight Watchers app.
I am synced with the FitBit app. I am set up with all day sync on the Fit Bit app.
I am shown as being connected on the Weight Watchers app via FitBit by allowing access. I have chatted several times with WW customer support, trying everything they have suggested. Nothing has worked.
None of my steps are showing on the WW app, although the FitBit app shows all my stats. So, I have received no pay-off via the WW app for all the activity I’ve had. In 2 days, I’ve had over 25,000 steps without a single FitPoint showing on my activity section on the WW app.
Any suggestion or assistance would be greatly appreciated. Thanks in advance for your assistance.
Moderator Edit: Clarified Subject and labels
11-10-2021 15:39
11-10-2021 15:39
I finally managed to sync mine after three days of trying. Maybe this will work for you.
In the WW app, go to settings and disconnect any and all fitbit devices. Now close out the app, and log in again before trying to add your device. Apparently, the WW app doesn’t clear out the old info unless you restart it.
09-14-2018 03:04
09-14-2018 03:04
Hello fellow WW member! Have you tried unsyncing it and then resyncing it? I have no problems with mine showing up, but it does seem the first time I did it it hesitated for a bit. Maybe it'll show up... sending you luck!
10-10-2018 06:27
10-10-2018 06:27
Were you able to get your Versa synced with WW? I am not able to so far and wondering what you did to get it to work.
03-22-2019 07:51
03-22-2019 07:51
Hi
I have the same exact problem and nothing I have done has worked. This is going on a month now and wow is this frustrating. Has your issue resolved and if so what did you do to fix it?
Thank you!
Lisa
03-23-2019 13:56
03-23-2019 13:56
Hello @Ljoy51 have a warm welcome to the Fitbit Community, it's great to have you on board.
I appreciate your participation in the Forums and for sharing your experience with us. At this moment, if your Weight Watchers activity points are not being counted, my best recommendation would be resetting the link between WW and Fitbit. In order to do this:
I hope this can be helpful, if you need anything else feel free to reply!
03-26-2019 04:14
03-26-2019 04:14
I am a new Weight watchers app user. Everything was fine, but yesterday the syncing section at the bottom of My Activity disappeared!! Just on my iPad. It’s still on my phone. I can sync on my phone and it does transfer to all devices , but I usually use my iPad. Tried all the tips and chatted with WW support. Still, gone Help please.
11-09-2021 07:30
11-09-2021 07:30
HI! Also having this issue, and this is where I am stuck on this process. I cannot re-approve app access via fitbit, no notifications are coming in to do so and there is not place on the dashboard on the browser or in the app to add app permissions directly through fitbit. Is there a workaround here or has an update maybe created an issue with app communications that prevents the access permissions email from being sent either as an incoming request from WW or as a received request from fitbit?
11-10-2021 15:39
11-10-2021 15:39
11-12-2021 06:33
11-12-2021 06:33
Welcome to the Fitbit Community, @dbmiller. Thank you for sharing the steps that worked for you to connect Fitbit with WW.
This information could be useful for other users.
Keep on visiting the forums.
11-29-2021 20:28
11-29-2021 20:28
This did the trick!!! Thank you so much for adding this comment, your a lifesaver! I had basically given up. Fitbit should definitely add this to their existing how to page for future users!
12-01-2021 11:11
12-01-2021 11:11
Thanks for getting back to us and for letting us know that the provided advise worked for you @tink101.
I marked it as the Best Answer to help other users.
11-14-2022 12:10
11-14-2022 12:10
I'm having the same issue with my Fitbit charge 4 not syncing with WW app. I've tried all the suggestions. Nothing! It's driving me nuts.
11-27-2022 16:10
11-27-2022 16:10
Same here. I have gone so far as to remove both apps, remove any data stored from both apps, reload both apps, relink and still it takes me closing and opening each app about 5 times before it will sync. Its super frustrating.
