12-20-2014 06:05
12-20-2014 06:05
Hi there! Couldn't find much on here about Runtastic intergration so wondered if anyone can help. Been using fitbit and MFP together for a while, and they seem to work perfectly together. A few weeks ago started running as well with Runtastic, and have it set up now so that account syncs both to MFP and Fitbit. Not sure whether I am trying to be too clever here as I am experiencing that Runtastic adds active minutes to my account and then so does Fitbit so I end up with double. Not sure what other problems this is causing. Thought that when they offered intergration they would have taken care of things like this though?
Anyway just wondering if anyone has a similar set up and any advice they might have for a noob!!!
Thanks! 😄
12-20-2014 08:38
12-20-2014 08:38
I had a similar situation with MFP and Endomondo. The solution was to connected both to my Fitbit account, but not to each other. Otherwise, you have Runtastic feeding both Fitbit and MFP and then MFP tries to feed the info it just got frm Runtastic back to Fitbit.
12-24-2014 02:17
12-24-2014 02:17
Right, will fiddle around and give that a go and let you know! Thanks!
02-16-2015 02:17
02-16-2015 02:17
Does this set up seem to work for you. I am not sure if I m doing it the correct way but.... I have linked MFP tto Fitbit and i have linked Runtastic to MFP. It seems to work, but I am not sure it is getting the best effect.
Thoughts??
