06-19-2017
10:01
16:48
AndreaFitbit
06-19-2017
10:01
16:48
AndreaFitbit
I purchased a Spirit Recumbent Bike, Model XBR-55 last week. In the users manual, it states that the Spirit Fit app syncs with Fitbit. I spent significant time on the Fitbit Chat support trying to find someone who would explain to me why I can't complete the sync. After speaking with 3 different people, all I was able to conclude from the discussions was that Fitbit had no record of this app relationship. I am including a picture of page from Spirit's manual. Any help with this would be appreciated.:
Moderator edit: format.
Best Answer06-24-2017 07:48
06-24-2017 07:48
Hi there @Spopar, good to see you again. You are correct, this integration does not figure among the officially supported integrations.
However there are many other apps that work with Fitbit, that are not officially supported by us, but in this instance is require to contact directly the developer of the integration to know more about the issue you are experiencing and how it works.
See you around and let me know if you have other concerns.
06-24-2017 07:56
06-24-2017 07:56
06-27-2017 11:43
06-27-2017 11:43
Hello @Spopar, thank you for keep me posted how it goes. I'm sorry about the integration, however we do not have control over the information it should sync SpiritFit, but I can give you the answer about your exercise.
Your tracker is designed to track your movement while your are going forward specially if the exercise include steps impact. Whit bike riding most of this motion pattern rely on your indoor bike, so your tracker finds difficult to read this movement as is not reading a motion of going forward. The best in this situations is to manually log your activities.
To log activities through your online-Dashboard:
If you are using iOS or Android:
Hope this helps and catch ya later!
Best Answer09-03-2021 16:36
09-03-2021 16:36
Would it work on the fitbit and track if you attach the fitbit to your leg while riding?
16:37
16:49
AndreaFitbit
09-03-2021
16:37
16:49
AndreaFitbit
HI, I just bought this bike a few days ago. I see same problem. The advertising brochure from Spirit has the Fitbit logo on it even.
@Spopar did you ever get it to link/sync
@RobertoME hello. I see this post is from 2017. Have there been any changes of support for Spirit with Fitbit?
Moderator edit: updated post.
Best Answer09-03-2021 16:51
09-03-2021 16:51
