07-30-2015
18:17
06:14
AngelaMa
07-30-2015
18:17
06:14
AngelaMa
Hello, my friends have the Fitbit zip and they sync to the Fitbit app and the my fitness pal app and everything works great for the most part. I decided to get one. I set it up and it was working fine, it still is but I have a problem with the data that syncs to my fitness pal. It shows my steps but in the food diary it shows zero for calorie adjustment. I need help please!!!!!!
@Ayesha1027 A warm welcome to the Community! It's nice to hear that you decided to get a Fitbit tracker
. It sounds like the apps are working properly, you may want to check What is the Calorie Adjustment in my Exercise Diary? because you're not going to see a calorie adjustment everyday if it's not necessary.
Keep me posted.
18:03
10:16
SilviaFitbit
09-28-2016
18:03
10:16
SilviaFitbit
I am having the same problem and I did get a calorie adjustment every day since last September....this past month has been a disaster it wont give me the calorie adjustment every day. I have to spend time connecting and unconnecting.... I need serious help because I am getting extremely frustrated.
Moderator edit: format
Allow me to help you @dianeb613! There were some issues with MyFitnessPal on 9/19 but this has been fixed. In this case, I would like you to contact MyFitnessPal directly so they can investigate more about it.
Thank you so much for your understanding.
