Fitbit currently does not have a partnership with mapmyhike. So, at the moment, you are out of luck. I am not sure if that is the same brand as mapmyrun, which does have a partnership with Fitbit. Maybe sometime in the future. Hope this helps! Let me know if you have any other questions! I am happy to help!
Best AnswerFitbit currently does not have a partnership with mapmyhike. So, at the moment, you are out of luck. I am not sure if that is the same brand as mapmyrun, which does have a partnership with Fitbit. Maybe sometime in the future. Hope this helps! Let me know if you have any other questions! I am happy to help!
Best AnswerHi Colin,
Thanks for responding. Mapmyhike shares login with mapmyrun, mapmyfitness etc..they are owned by under armour based on what I found online this afternoon. I will try it again tomorrow. If it works great, if not I will do the manual export/import for the you vs the year 2017 challenge.
regards,
silita
Well I have figured out a workaround...I track the walks with Fitbit app for the gps and then I have it linked to strava so it's automatically sent to strava and I export the gpx from strava and import into mapmyhike for now...And I can export my prior mapmyhike walks to strava and it will get to fitbit
