12-21-2016 06:48
12-21-2016 06:48
Good day I hope you can help me out. I have a Garmin Vivoactive HR synced up to my Garmin Connect account. Most others I know use FitBit, so I found the Fitdatasync.com hoping to be able to transfer by Garmin info automatically to my FitBit account. It doesn't seem to work, I have both my account info saved into the site, when I press the synchronize now, it gives me the "Failed to sync" error....
Any help with syncing the accounts would be greatly appreciated!
12-21-2016 18:22
12-21-2016 18:22
Anyone able to help out? Is it just that FitDataSync.com is down right now?
12-22-2016 16:51
12-22-2016 16:51
Allow me to help you @toonpopo! Currently, Garmin data and Fitbit aren't compatible apps anymore. They used to sync in the past by using a third-party app. However, it isn't listed as supported anymore. (You may want to contact Garmin in case they can provide you with more information about it)
Additionally, you may want to vote for this idea Garmin Connect Integration because those suggestions are viewed by our engineers and developers and the best of this is that people can vote for them.
Thanks for your understanding.
