08-02-2014 09:19
08-02-2014 09:19
Hello,
Regarding healthvault integration:
1) can you tell me how often fitbit measurements sync with healthvault? Weight measurements show up in fitbit, but don't show up in healthvault for a very long time. My withings scale measurements show up in healthvault instantaneously.
2) does healthvault integration comply with healthvault API and data structure requirements? Although I can eventually see fitbit weight and body composition readings in healthvault, they don't seem to transfer from healthvault to third party apps (like livescape on windows phone). However, the same weight and body composition readings from my withings scale easily transfer from healthvault to the same third party apps.
Thank you.
Best Answer08-02-2014 12:28 - edited 08-02-2014 12:29
Healthvault takes longer to sync than most other apps. Also, Healthvault does not allow a two way sync. They only let info in, not out... at leats with Fitbit.
Best Answer08-02-2014 12:51
08-02-2014 12:51
