04-16-2016 12:54
04-16-2016 12:54
It's nice to see you around
! Your Fitbit stats and dashboard can integrate with MyFitnessPal by exchanging data.
To get started with MyFitnessPal, you'll need to create a MyFitnessPal account at http://www.myfitnesspal.com. Next, link that account to your Fitbit account. To do so:
If you're interested in exporting your GPS data from Fitbit Surge to MyFitnessPal, see Can I export my fitness data to my computer?
Catch you later!
04-17-2016 04:35
04-17-2016 04:35
Enjoy the noms ![]()
Best Answer11-21-2019 23:06
11-21-2019 23:06
Hi,
When I do this, it says it is already connected to another Fitbit. I used to have an old Fitbit but now I have a new one but using the same account? Can you help me deactivate the other one so I can use MFP with my new one.
Best Answer12-10-2019 17:51
12-10-2019 17:51
I was receiving this message myself. My problem was that I didn't realize I had two MFP accounts (two different email addresses). My fitbit was attached to the one with an old email. Check to see if MFP recognizes another email by trying to login. Select reset password and see if it recognizes your email(s). Once I figured this out, I disabled one of the MFP and was able to connect the devices. Good luck.
Best Answer04-30-2020 02:41
04-30-2020 02:41
Hi, is there a way to pass my food logs data and nutritional values from myfitnesspall to fitbit?
It seems fitbit can import only the intake of calories amount per day from myfitnesspall, and the fitness activities with consumed calories l log there...
