I haven't purchased a fitbit yet, I wanted to see how the app and website worked first. One of the things that I liked the best about fitbit is that you can sync it with My Fitness Pal because that is what I already use. But I can't figure out how to sync them, any help?
08-21-2014
11:48
06:41
08-21-2014
11:48
06:41
@whitneyh6 A warm welcome to the Community and Fitbit Family
To link your two accounts, please go here and click “Get Started”. You will then be prompted to either log in or sign up with your MyFitnessPal account.
Once connected, you will be able to view the foods and activities that you log on your MyFitnessPal account on your Fitbit Dashboard.
08-21-2014
11:48
06:41
08-21-2014
11:48
06:41
Hi,
the click here link is not opening,, do you happen to have the actual link that I can copy to get there?
thanks Melissa
Best AnswerSilvia's link does not appear to be working.
Here is the actual link: https://www.fitbit.com/apps/myfitnesspal
Thanks for the link @SunsetRunner I'm sorry that the link I provided wasn't working ![]()
Best AnswerHi. Just got my Fitbit Flex yesterday, so maybe I'm not doing everything 100% yet.
I have been using My Fitness Pal and Map my Walk since September 2014. Yesterday I felt that I linked the Fitbit to My Fitness Pal. At least it says I did. I unlinked Map my Walk. So far I can't see my meals on the Fitbit Dashboard, or the miles walked on My Fitness Pal. Any suggestions?
09:39
06:38
04-17-2015
09:39
06:38
@dinnerbelle It's nice to have you here! I would like you to go to your Dashboard > click on settings > Applications and there you'll see MFP and MMW. If after checking that you're not seeing any apps linked please link the accounts again to Fitbit by checking this article.
Best AnswerYou had a space character in the link between "http://" and "www.fitbit.com/apps/myfitnesspal" It shows up in the URL as "%20". Once I removed that it worked fine.
@DrewGator It's great to have you here! thank you for sharing this, I clicked on the link and I was able to get the page, hmm weird ![]()
@Smudgecat Welcome to the Fitbit Family! I hope I can continue seeing you around, you may want to check the Discussions Board and meet new people. ![]()
Best AnswerSylvia, When I go to my settings and then to applications, all I see is Facebook. There are no other apps to chose from. (I'm trying to connect my Fitbit to My Fitness Pal). Please advise.
11:54
06:38
01-09-2016
11:54
06:38
@vlwarner Welcome to the Community! The procedure to link Fitbit and MyFitnessPal is a little bit different, please follow the linking procedure. When you go to settings > Applications > you're going to see the applications that you've linked. As an example as soon as you link Fitbit with MFP the third-party app should show there.
Let me know how it goes
Best AnswerI have a flex and have been logging food on myfitnesspal. How do I get the steps that show on my fitbit to show on myfitnesspal? I clicked on the mfp app, clicked on the fitbit tracker app, clicked connect, and....nothing. Please help
04:45
06:38
05-23-2016
04:45
06:38
@Bobbinyc A warm welcome to the Community! You may want to try to connect both apps using a computer, here's the procedure:
Also, Fitbit steps and sleep data can be viewed in the "check-in" section of MFP.
Hope this helps.
