10-14-2014 07:48
10-14-2014 07:48
17:59
06:04
11-20-2014
17:59
06:04
@Gill2085 Hey there! You may want to check this help article about how to connect them.
Best Answer10-14-2014 10:05
10-14-2014 10:05
Go to the weight watchers site. Click on Account Settings then look for Link Activity Trackers. Choose fitbit and go thru the process
Wendy | CA | Moto G6 Android
11-20-2014
17:59
06:04
11-20-2014
17:59
06:04
Best Answer05-03-2015 06:37
05-03-2015 06:37
I'm trying to connect my Charge HR to WW. just replaced the 'one' -- which I ALSO had the same problem.
In the last post, I found no place on WW site that let me do this:
To give Weight Watchers access to your Fitbit data, enter your Fitbit account credentials and click Allow. When the accounts are connected you'll see a confirmation page.
Please help.
also, do I need to connect from the fitbit app, too?
09:16
06:04
05-04-2015
09:16
06:04
@dunlop4 It's nice to have you here! You need to do this procedure from the computer, check this article which is the same that's in the post above; there are the steps you need to follow to link them.
Let me know if you're getting any error or you're not seeing the same as it's showing in the article.
Best Answer05-29-2015 07:08
05-29-2015 07:08
Thanks so much I will give it a try. But my issue is that it says I'm already connected. I might have to disconnect and then reconnect. Thanks!
Best Answer05-29-2015 07:20
05-29-2015 07:20
ok so ive gone back in and re synced my fitbit. But my WW app doesnt show anything.. Is it suppose to show something?
Best Answer11-04-2015 06:31
11-04-2015 06:31
Followed instructions on the page and while not quite the same, I think that it worked. Now I have to charge my HR charge (for some reason that is funny to me, a charge only lasts about 30 hours) and see if I am indeed linked.
