01-17-2017
06:02
07:58
LanuzaFitbit
01-17-2017
06:02
07:58
LanuzaFitbit
Has anyone been able to linc up with Fitcoin. The app says it will sync with FitBit but I have been unable to find the app in "compatible apps"
Best Answer01-20-2017 08:01
01-20-2017 08:01
Hey @TinaN! Thanks for stepping into the Forums.
After doing some research, I couldn't find any specific way to connect FitCoin to Fitbit. It would seem, from the description on Apple's App Store, that it needs to be connected to the Apple Health App. In that case, you'd need to connect your Fitbit account to your Apple Health app using the IFTTT app and then connect Apple Health to FitCoin.
I hope this helps you out! Let me know if you have any further questions.
Best Answer09-05-2017 07:48
09-05-2017 07:48
Hi there! I am also having the same problem and my Apple Health does not even show up as an option to connect to Fitcoin and only Fitbit. I have tried deleting and reinstalling, turning my phone off and on, and uninstalling the app then turning it on to download again. When I try to link my Fitbit to fitcoin, the authorization window pops up for 2 seconds before it disappears and returns to the link my devices menu. Thank you in advance for your help. I've been trying to get this work since all last night!
Best Answer09-07-2017 14:17
09-07-2017 14:17
Welcome to the Community @ahng002.
Perhaps the best way to go about it would be to contact Fitcoin directly. They should be able to check on what is going on.
