If you set up your SmartBand using NFC, you are guided during setup to Google Play, from where you can install the necessary applications to use with your SmartBand. If you set up your SmartBand using Bluetooth, you have to go through some extra steps to install the necessary applications from Google Play and connect to your Android device. Now you can connect fitbit with smartband by choosing any of one option.Get full explanation about these both concepts at - Sony SmartBand SWR10 Manual. ![]()
