How to connect to withings scale
Directions say to go to apps and devices, but the scale does not show up. How do i pair the scale and the Fitbit.
1 REPLY 1
To connect a Withings scale, you'll need to use the Withings Health Mate app and enable Bluetooth on your smartphone. First, download the app and create or log into your Withings account. Then, navigate to the device setup  monkey type  within the app, select "Scale," and follow the on-screen instructions to pair your scale via Bluetooth and connect it to your Wi-Fi network.  Ensure that your Wi-Fi network is functioning properly. Try connecting another device, like a phone or computer, to check connectivity. Make sure your scale is within range of your Wi-Fi router. The closer it is, the better the connection.
