01-15-2020
08:22
13:36
SilviaFitbit
01-15-2020
08:22
13:36
SilviaFitbit
How do I sync my Inspire HR to My Fitness Pal
14:14
11:02
01-16-2020
14:14
11:02
@Fiamia Welcome to the Community. I'll be happy to help you answer your inquiry.
Please follow this procedure to connect Fitbit and MyFitnessPal:
I'll be around if you have any additional questions.
Best Answer01-16-2020 14:53 - edited 01-16-2020 15:02
Hi: I do not see "connect" on My Fitness Pal and the "Apps and Devices" brings me to Fit Bit App which shows my Surge. I had a Surge Fit Bit and that is in there but now I have an Inspire HR.
12:17
11:01
01-18-2020
12:17
11:01
@Fiamia Thanks for getting back.
Since you mentioned you had a Surge but now have an Inspire HR, your apps are connected. You can double check this because Fitbit will show the installed button, check the screenshot below:
You don't need to do the procedure again. Check this post to learn more about what will sync between Fitbit and MFP.
