08-19-2014
11:52
13:15
AngelaMa
08-19-2014
11:52
13:15
AngelaMa
I've just got a Fitbit flex and want it to synch to MY Fitness Pal. It is showing as being recognised on my exercise page in MFP but is showing no details. Please could someone tell me what I'm doing wrong??? TY
08-19-2014
12:10
19:14
EstuardoFitbit
08-19-2014
12:10
19:14
EstuardoFitbit
@Janch57 A warm welcome to the Community!
Fitbit will sync steps and calories to MyFitnessPal. Fitbit steps and sleep data can be viewed in the "check in" section of MFP. If you're not seeing anything, please confirm if your Flex is already set up to your account.
08-19-2014 12:39
08-19-2014 12:39
08-19-2014 13:28
08-19-2014 13:28
On the MFP Android app, info is listed under "Progress". You can see steps, measurements, sleep, weight, etc. What specifically are you looking for?
08-19-2014 13:44
08-19-2014 13:44
08-19-2014 14:40
08-19-2014 14:40
Why not just leverage the Fitbit app if you want specific calories burned for the steps taken? Let Fitbit do what Fitbit does well.
08-20-2014 00:28
08-20-2014 00:28
08-20-2014 22:47
08-20-2014 22:47
Have you looked at the Fitbit dashboard? The full dashboard gives you access to most pieces of data that you are probably looking for. If you insist on using a mobile version, the app shows calories burned over time...at least my Android app does which tends to unfortunately lag behind the iOS app.
