I use IFTTT to log the daily activity Summary to a google spreadsheet.
While this allows me to check burned calories, there is no option to export the calorie intake.
Since this data can be gathered from the Dashboard and user data export ( https://www.fitbit.com/export/user/data ) i would ask you also integrate this function into the IFTTT channel. I'm not sure how adjustment of the IFTTT channel works (ie. does fitbit or IFTTT do it?) but i thought this might be the right place to ask.
Best Answer"Recipes" in IFTTT are user created based on what data is available in the channels. Fitbit provides a free and open API for 3rd party developers to use to integrate Fitbit data with their apps, in this case IFTTT. Fitbit has no control over how that data is used or what data is used. Your caloric intake is certainly part of that data. It is up to the channel developer at IFTTT to use it.
