10-27-2015 00:58
10-27-2015 00:58
Hi, I got my Fitbit Surge yesterday and I love it! However, a couple of questions regarding its use with Endomondo.
1) Am I right in thinking fitbit only sends over the stepcount data and not the full run details (such as route, distance etc.). Will this change in the future?
2) Because of the above, I exported a run I had done using my Fitbit and then imported it into Endomondo (tcx file). It came up with the map and everything. However, will this double count my calorie burn and distance on Endomondo? One from the stepcount and then from the imported run.
3) After doing the above, I noticed that Fitbit had added the run I had imported into Endomondo as a new run. So my exercise history on Fitbit stated that I had done the run on Fitbit and I had done a separate run at the same time on Endomondo. Again, this means the the run will have been counted twice.
Hope you can help, would love to be able to have good synergy between fitbit and endomondo.
Best Answer10-27-2015 03:13 - edited 10-27-2015 03:15
Have moved your post from the Surge to the Third-Party Integrations section to increase the chance of getting a solution.
Your post will get more attention here.
Wishing a wonderful day
