11-20-2014
10:35
11:41
11-20-2014
10:35
11:41
@Leedube It's great to have you here! MyFitnessPal will sync just activities and logged food to Fitbit. Fitbit will sync steps, calories and Aria measurements to MFP. You can only see the weight report in both Fitbit and MFP but manually logged weights won't sync.
Wendy | CA | Moto G6 Android
Best AnswerI have over 1 year worth of weight history in MFP. After linking my FitBit account to MFP the weight history did not carry over to fitbit. I want to import the data from MFP to fitbit.
The only data that will sync is what MFP allows/releases. Not all apps will sync everything. You need to ask over at MFP.
10:35
11:41
11-20-2014
10:35
11:41
15:31
11:42
02-14-2015
15:31
11:42
@pouls29 Yes, you can export your Fitbit data as CSV or XLS file just do the following: Go to your Dashboard > Click on settings > Data Export > Choose the data you want to export > choose the file and finally click on Download.
You can also export your data in MFP; however, you won't be able to input any data in Fitbit by just logging the whole document, you will need to manually log any new information that you want from MFP to Fitbit.
Hope that helps.
14:03
11:42
02-24-2015
14:03
11:42
@Scandia4 I'm sorry for the delayed reply. When you're exporting daily data you will just need to choose the dates in the calendar, go to your Dashboard > click on settings > Data Export > Time period you will need to choose the dates and meaning just one day and later click on "Download".
Wish you the best ![]()
