09-15-2016 04:01
09-15-2016 04:01
I've recently joined a David Lloyd gym, is it possible to sync activity with their 'BodiTrax' system?
09-15-2016 07:36
09-15-2016 07:36
Fitbit provides a free and open API for 3rd party app developers to use to sync data between Fitbit and their apps. You would have to ask over at BodiTrax if they are using this or if they have any plans to.
Best Answer09-16-2016 04:45
09-16-2016 04:45
Thanks, I contacted BodiTrax - they confirmed they are in the process of testing to get a full integration with Fitbit. 🙂
10-30-2016 01:40
10-30-2016 01:40
This is execlent news
Best Answer01-18-2017 00:36
01-18-2017 00:36
Any indication on when BodiTrax will release their integration with Fitbit? And if they already have how can you sync the two?
05-25-2017 04:20
05-25-2017 04:20
Hi, does anyone know if this is available as yet ? Thank you x
06-29-2017 09:33 - edited 06-29-2017 09:34
Integration with Fitbit trackers is already listed as a feature on Boditrax website under the heading "Enhanced dynamic integrations"
See http://discover.boditrax.com
Is it not working?
Best Answer06-29-2017 09:40
06-29-2017 09:40
Best Answer07-01-2017 08:20
07-01-2017 08:20
Hello @shepp27 and @nzkiwi103 welcome to the Fitbit Community and nice to see you again @SarahEE.
I was looking about Boditrax and the link you shared @nzkiwi103, however I wasn't able to find more details. Note that this is not listed as supported third party app, however there are many other apps not officially supported that uses our open API.
In this case it would be recommendable to contact the developer of Boditrax for additional support. As we do not have control over this data in order to provide more information.
See you around and stay tuned to the Fitbit Community.
Best Answer03-11-2018 16:04
03-11-2018 16:04
Hi
A year has gone by since the last post. Any progress?
Best Answer03-14-2018 04:52 - edited 03-14-2018 04:53
Hello there @NickNottingham, thank you for visiting the Fitbit Community and checking the progress of a possible integration with Boditrax.
So far I have't received new updates to report about Boditrax. Keep in mind that most of the third party integrations are not developed by our initiative. It would be recommendable to contact the developer of Boditrax to learn more about their future plans and if there is an integration with Fitbit on the way or in a near future as I suggested in my last post.
For more details please refer to our Third Party Apps - FAQ.
See you later.
